7 members (1955 1 Series, cmayna, Gray_Ghost, JW51, Pete1946, 55shaker, 1 invisible),
157
Mod | | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Hi all,
Thanks to a fellow called Wrench Fetcher and others I finally have a 2 speed diaphragm coming in the mail. I have found out one thing since starting this project and that is if you look hard enough and with a little help you can find a lot of this old stuff.Thanks to all who posted for the help cause I am sure I'll be needing more in the future.
Resp. JMH | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jmh, you owe your thanks to "Lightholder's dad", "Wrench Fetcher", is a term they use here to describe how many posts you have made, for example, the term they are using to describe you is "Apprentice", because you have made a very limited number of posts so far, hope that helps. | | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | To all,
I stand corrected. The term "Apprentice" fits me to a " T " .
Thanks again, JMH | | |
