| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 40 New Guy | | New Guy Joined: Aug 2010 Posts: 40 | Hi! I have a problem that I'm not sure what do to about. I've found that at very, very low throttle (the barely-pushing-the-pedal in stop and go traffic kind) my engine wants to sputter and die. It idles just fine, and at higher throttle it goes ahead and picks up and runs normally. I've tried adjusting the ratios on the carb, but haven't had any luck. I have a 350 engine and non-points ignition system. Thanks for any advice! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | a bad vacuum advance would give those symptoms
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Also you might try advanceing the spark a little & richening up the idle jets. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 40 New Guy | | New Guy Joined: Aug 2010 Posts: 40 | a bad vacuum advance would give those symptoms
Bill Sorry, i forgot to mention i have an electric distributor. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ah - you did say non-points ignition, my miss ... so what bender says, try more advance
Bill | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Maybe the accelerator pump? | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | chicklin, that's what I was thinking also.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Aug 2010 Posts: 40 New Guy | | New Guy Joined: Aug 2010 Posts: 40 | Ok, i will check these things tomorrow night when i have some time. Timing i can do, not sure how to diagnose/fix the accelerator pump on the carb. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | for a start on the pump, watch down the carb throat [engine off] as you tweek the throttle linkage, should see an immediate squirt of gas - if not or it seems a "delayed reaction" open the carb and pull out the piston and see if the leather/rubber sleeve is deteriorated
Bill | | | | | Joined: Aug 2010 Posts: 40 New Guy | | New Guy Joined: Aug 2010 Posts: 40 | I probably should have put this in one thread, but i had an overheating issue yesterday. Could the timing be off far enough to cause both these problems? | | | | | Joined: Aug 2010 Posts: 40 New Guy | | New Guy Joined: Aug 2010 Posts: 40 | Ok, checked the accelerator pump, and it looks ok. I have a 4 barrel carb, and the front two give a little squirt of gas. Didn't have time to mess with the timing, since there's not much daylight left when I get in from work. Will try to find time tomorrow. | | | | | Joined: Aug 2010 Posts: 40 New Guy | | New Guy Joined: Aug 2010 Posts: 40 | Ok, Pulled out a timing light and a engine gas analyzer and got my timing and fuel/air mixture right. the problem is mostly gone now. Thanks for the help everyone! | | |
