2 members (49 panel, Hotrod Lincoln), 42 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#669610 08/11/2010 8:18 PM
can i use a 12v battery to turn over and get my 46 to run all lights are gone just hate to buy a ney 6 or 8 volt battery to find out the motor is no good will it start and run on a 12v battery for a short perioid od time if i still have the 6v generator on truck ?????????????
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Yes it will be alright for a short time.
BILL #669626 08/11/2010 9:13 PM
Riding in the Passing Lane
Disconnect the main feed wire that comes off the starter post & the wire going to the coil from the ign. switch. Then use a jumper wire from the pos. to the coil. You should put a resister in the wire going to the coil or you will burn the points.
1972 Chevy c10 Cheyenne Super
thanks guys for the info guys
AND A MARINE
Hope you disconnected all the guages as well. The lights will (would have been) be fine if you leave them off.
I plan to do the same thing with my truck in the next couple of months. I purchased the truck months ago and am storing at sisters farm until I finish up all my other projects and make room. First thing I want to do is check the health of the engine. But, I dont want to buy a 6 volt battery only to have it sit for years while the truck is being restored. I plan to disco everything and just put 12 volts straight to coil and starter. Not even worried about burning up the points, as that will take awhile. Or, I might just put one of my ballast resisters (from inboard boat engine) between the battery and coil. Don't back feed anything you dont want to see 12V.
