1 members (59 fleet),
62
9
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | In a recent post I described a problem I am having with the carb. on my 48 Loadmaster. I put a kit in it and it still wont run without the choke about half the way out. I double checked for vac. leaks and have none.When you drive it on the open road it acts like it is starving for gas.It is a Rochester mod. B Any ideas.
Thanks, JMH
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Have you had a vacuum gauge on it while driving. Sometimes leaks are not that obvious. If you have PVC, the valve could be stuck open, a 2 speed can cause a big vacuum leak or even a wiper motor. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Check around the throttle shaft. It's a hard one to see, but if you spray a little carb cleaner right where the shaft exits the carb body on either side, the pitch of the motor might change. If it does, you've got a leak.
I have the same problem and one of these days I'm going to get it drilled out and put a bushing in. It runs fine above idle, though, so yours may be a different problem. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like you are running lean. Pull the top off the carb & see what size main jet is in it. If it's a 216 you want about 53-55. If it is a 235 56-58. Check the float level. If it is correct you may want to raise it up 1-2/32's. Make sure the power valve piston works free & goes in the hole & knocks the ball off it's seat. You might advance the timing a little. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
