3 members (Hotrod Lincoln, 2-Ton, 1 invisible), 63 guests, and 4 robots.
Topics128,021
Posts1,055,353
Members48,420
#668950 08/09/2010 5:57 AM
I have a 1949 1 ton gmc i am having trouble finding out just what engine i have the codes to the rear of dist cap and dip stick read CON3 H94 doesn't match any of the list i've looked at any insight would be great thanks,oldsklmarine carrollton ohio
That isn't the number you use. There should be an engine number stamped on a pad behind the distributor It will start with a letter then the next three numbers tell the size of the engine.
On the other side of the block there will be a 7 digit number cast into the block. With that you can find more info on the block.
The number you posted shows the date it was cast. H means August, 9 is the day and 4 is the year. Probably '54 but it might possibly be a '44. That 3 digit code on the engine number will clue us in.
great thanks for the info looking forward to getting back home to check it out thanks!!
