6 members (Oswald, farmallb, Stovebolt48, GrandpasJimmy, 2 invisible), 132 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#66858 10/05/2006 10:03 PM
Junior Member
Junior Member
WHAT T5 TRANSMISSION IS GOOD TO GO BEHIND 305 V8 AND 411 REAREND. IS THE S10 V6 5 SPEED O.K. WILL IT FIT????
#66859 10/05/2006 10:19 PM
Riding in the Passing Lane
The s-10 is the best one for the old chevy trucks. They fit with minor modifications. There is info on the tech section or you can do a search. Much info has been posted on this websight. The 87 back has mech. speedo drive & are the best to use unless you have custom gauges with electronic speedo. Some say they are too light duty for a v-8 but i ran one for a while behind a 350 & am doing another one now. I feel if you don,t torture it, it will last.
1972 Chevy c10 Cheyenne Super
#66860 10/05/2006 10:27 PM
Junior Member
Junior Member
WRENCH, WHAT TYPE OF MODS. MAY HAVE TO BE DONE.
#66861 10/06/2006 10:46 PM
Well I tried being lazy & let you search the archives. But here goes. Cut off part of the front bearing retainer to match the old trans. Cut off part of the end of the front drive gear where it goes in the pilot brg. to match the original trans. Use a die grinder & lenghten the splines the clutgh disc rides on a little. Drill the mounting holes out to 1/2 in. After installing the trans. measure the drive shaft & have it modified to the correct length.
#66862 10/08/2006 5:23 PM
I also had to take about 1" off the linkage that actuates the fork in order to keep the clutch adjustment in the center of the threaded rod.
#66863 10/09/2006 1:22 AM
Z
Z Offline
why not get a t5 from a 305 camaro/firebird and find a s10 tail section?
#66864 10/09/2006 6:15 PM
Junior Member
Junior Member
zenish, do the t5 you are talking about have to come from the 80-90s or do it matter the year????
#66865 10/10/2006 2:25 AM
Z
Z Offline
get one from a 83 to 90?.86 to 90 are "world class "which are better.you could use a later one only if your speedometer is electric.
