| | | Forums66 Topics128,089 Posts1,056,138 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | This seems to simple to ask, but is there a trick to removing trim rings from the wheel? Mine are aftermarket stainless but seem a bit thin so I don't want to muscle them the wrong way and dent them. I tried a screwdriver about 1/2" across on the outer lip. It seemed it would bend and maybe crease if I kept prying so thought I'd go to the brain trust again
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A lever with a wide/broad head might work. A hub-cap removal tool.Note that some trim rings (and wheel covers) have sharp inner teeth to hold them tightly to the rim. These types of rings will unavoidably scratch the rim. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks Tim. I got one off using the hubcap tool from my wife's Pt Cruiser since I don't have one for the truck. Thanks for the tip. I used a broad tip screwdriver to start it then slowly worked my way around the rim with the hubcap tool. Now on to cleaning and painting! Thanks again
40 Chevy 1/2 ton
| | | | | Joined: Oct 2008 Posts: 21 Apprentice | | Apprentice Joined: Oct 2008 Posts: 21 | Hit a pothole @ 40 mph has always worked for me
Blue 666
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | On a side note, I have a 60 vette with full coverage wheel covers, that are tighter than anyhting to get on and off. Also at Harbor Freight, they sell a pack with 4 small yellow pry tools of differant shapes, that are made of a glass filled plastic. They are quite hard, but they will not scratch your stainless or your paint. I have used them a number of times with no problems. They will eventually break the ends off, but their rather inexpensive, and I would recommend getting 2 packs while your there. If you need a part number, I can get it out in the garage. | | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | I bought a set of these tools from HF. About $5 IIRC. Used for interior trim removal. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
