1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | All my air lines are brass pipe. There is about 120' of brass lines. Note always pull off the top of the air line for your air needs and add drip legs at the end of the run. The line needs to run at a 1/4" per foot of fall from the compressor. This will move the water to the drip leg at the end of the run. Use copper pipe. Good Luck
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
