5 members (Nick in Manitou, Peggy M, UtahYork, Southerntruck, 1 invisible), 140 guests, and 6 robots.
Topics128,077
Posts1,056,014
Members48,433
#667298 08/03/2010 4:45 AM
i rebuilt my motor (63' 327) and i was wondering what a good starting point is for the idle adjust screws. i have a rochester 4jet (not a quadra jet) the only changes i made from stock are a little bigger cam, roller rockers, and some custom milling on a 283 intake manifold that came with the truck. nothing major- just gave the dual rise more common plenum area to help the a/f mix. other than that is stock specs.
66' Chevy C-30 Rat
It is probably a Rochester 4GC. Try screwing the screws all the way in and then about a round and a half out and start from there.
3B Offline
Hy BrianToste, try 1 1/2 turns out as a baseline, you can tune it much finer while it's running. Do you have a vacuum gauge?
3B #667326 08/03/2010 12:30 PM
a little bigger cam
What duration @ .050"?
You cut down the divider wall? How much? That reduces idle vacuum somewhat, which may require richer mixture (and so may the cam).
How many turns out gives the fastest idle?
Carburetion specialist
Originally Posted by panic
a little bigger cam
Totally agree. Also, if you live in an area where you have to burn ethanol, you may need to increase the diameter of the idle jets (as well as the main jets).
Jon.
The Carburetor Shop
i do have a vac. gauge. the cam duration is 224 int. 234 exh. i took out most of the d1vider wall i havent tried to do any tuning on it yet- i just got it fired up over the weekend. havent timed it or anything. i was just looking for a good starting point with the idle screws
66' Chevy C-30 Rat
