3 members (Gdads51, Otto Skorzeny, Barney1951), 62 guests, and 1 robot.
Topics128,080
Posts1,055,946
Members48,430
#667103 08/02/2010 2:02 PM
I'd been driving my '59 3800 with a 235 regularly until a couple years ago. A couple things parked it and I'm just trying to get back to it. Now it won't start.
I'm thinking that I'm not getting fuel. This rig has had fuel pump problems in the past so I'm leaning that direction. Can I get a fuel pump at NAPA or Advanced Auto? Or do I need to order this from LMC or something?
Also thinking I should think maybe replace the plugs/wires/distributor cap/etc... can I get these regularly?
Y
Y Offline
Your local flaps should have the majority of the parts you need, if not they can order it in and it will cost less than having a vender ship it to you.
OK, I was hoping that was the answer I was going to get. But I thought I'd ask and save myself the trip to flaps... To be honest, I haven't had the best luck with NAPA & Advanced having the parts I need recently...
I hope you are using new fuel.
If it won't "try to start" with a squirt of starting-fluid, it's ignition.
Yeah, I siphoned out as much of the old gas as I could get out and put in 2 or 3 gallons of fresh fuel. Wouldn't fire - even with starting fluid.
So, 54 5-window, if it's the ignition, what do you recommend I do?
