1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I fired up my 292 engine last night for the first time since having it honed and putting all new "guts" into it. It started and ran just fine with just little bit of lifter chatter. Near the end of a 20 minute "warm-up," I could hear a sizzling noise from the rear of the engine.
I turned off the engine and traced the noise to some water (used only water - no antifreeze for the start-up) sizzling and sputtering around the rear-most exhaust manifold allignment pin.
Does the pin go into the water jacket? Can I remove it and seal it some way? Has anyone ever run into this before? (The search engine turned up nothing) Might it seal itself up with use? Any help would be appreciated!
Thanks, Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | You should be able to remove the alignment pin and replace with a bolt or stud, and sealer. The pin is threaded, use a pair of vise grips and unscrew it.
I haven't had one leak on me.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are freeze plugs in back of the manifolds that are known to leak. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Thanks for the quick responses! I don't think it is a freeze plug - I have the front sheetmetal off and could see the leak with a flashlight. I didn't even think about the pin being threaded. Maybe some high temp. thread sealant would stop the problem. What's interesting is that it didn't leak before the engine rebuild process. . .maybe it was plugged with 45 years of caked on grease!
Craig
CK
