1 members (Peggy M), 121 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
After a very successful T-5 transplant,it is now apparent that the differential has some issues. The pinion bearings and races in rough condition. No damage is noticeable inside.
Should I look for a rebuild or look to see if one might be found from the Stovebolt family?
3B Offline
Hy robert giles, please remember to tell us what year/size truck you are asking about, thanks.
the pinion bearing/seal/crush should be available from NAPA or similar, if the gears look good it's worth repairing if you can't find a good one nearby cheap
Sometimes I type without thinking.
1955 Chev 1/2 ton 3100 2nd series
Riding in the Passing Lane
I would get a good used center section. They are plentiful & easy to change. If your brgs are bad you have probably wore 2 different patterns in the ring & pinion & it will always sing.
1972 Chevy c10 Cheyenne Super
