5 members (Goach2, Hotrod Lincoln, Gdads51, Sjm, greenie-reddy), 92 guests, and 2 robots.
Topics128,264
Posts1,058,352
Members48,485
#666564 07/31/2010 2:44 AM
I'm thinking a hidden ignition disable switch would be a good idea.
Any suggestions/diagrams how to proceed?
thanks,
H Online: Content
The simplest kill switch is just a toggle switch hidden under the dash somewhere that shorts out the distributor primary circuit. On a HEI system, the TACH terminal gets connected to ground with the remote switch and prevents the coil from firing. A more sophisticated system might involve a timer that lets the engine run a few seconds, then shuts down the ignition system. With some basic electronic knowledge and a couple of relays, a system can be designed to blow the horn and flash the headlights after the engine stops until the battery runs down or a cable gets disconnected.
Depends on whatya wanna do, how elaborate you want to make it.
Simplest route is a hidden switch, maybe one like this one from Speedway Motors that can cut the battery & ignition. Mount up under the dash wehre it's hard to see or in a fender, so long as your hood locks it's pretty hard to bypass.
I've seen simple circuts that use relays powered by a hidden switch that cut the battery and ignition circuts, or a variation on the theme that require you to turn on the key then pass a magnet over a hidden reed switch to engage the relay, shutting off the key resets the whole thing.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
H Online: Content
One that's really hard to bypass involves using a plug-in type headphone jack. The ignition and/or start circuit goes through a jumper wire in the phone jack, and once it's removed, turning the ignition key has no effect. The female socket can be located in a hard-to-see place to hide its real purpose.
I've been thinking about that, too... How can I lock that hood?
I thought a cable lock might work, but have not figured it out yet...?
if you know how to hot wire? then it's easey. just install a swicth to open the curcuit to the pos. side of your coil after your ignition switch. Hence no power to the pos side of the ciol no start.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
To lock my hood I found a Masterlock bicycle cable lock that has a slider lock that allows you to adjust the length of the cable. I run it up behind the hood latch then down around the grille braces in front of the radiator.
However GMC's allow a bit more room for reaching into the grille, so for your chev you may ned to get more creative. On my '65 Chev I ran a cable down to the frame rail so I could reach the lock behind the bumper.
:P
Check in the Tech Tips for a locking setup, I belive that is where I saw it.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Wow! Tech Tips! what a good idea. There's a bunch of stuff I can do in there.
I like the lock idea, and I finished the hidden switch up under the dash this last weekend!
thanks for you help.
