| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66611 09/28/2006 3:41 PM | Joined: Jul 2006 Posts: 11 Junior Member | | Junior Member Joined: Jul 2006 Posts: 11 | I can't figure out why my 216 will idle for 10 minutes with the temperature staying fine and then when I take it out and start running the truck down the road it starts to overheat. I pull it off the road and let it sit with the idea that I'm going to limp it back home and when I start back, the temperature is fine. This scenario has happened twice in a row. I have a new thermostat but I must be having some kind of air lock in the system. Does anyone have an idea what might be happening? | | |
#66612 09/28/2006 5:40 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | scottbit,
The problem 99% of the time is a old, plugged radiator.
A thermostat can stick, but this isn't normal. If you truck does this every time, that means the thermostat would have to malfunction the same way every time too...not likely.
You installed a new thermostat...why! Was the truck doing the same thing with the old one?
The gauge is showing hot...is the engine actually hot. You can smell/feel a hot engine.
A thermometer in the fill spout would confirm the accuracy of the dash gauge.
Did something happen to the truck before this happened. Did you tune it up and time the engine.
The plugged cooling system system would not allow the engine to cool down and run normally after sitting a spell, it would always cause the system to run hot.
I think the course of action would be to see if this actually a periodic heating, or is it really a constant problem while running the engine.
The thermostat has to be installed with the proper side to the block. If you want, you can remove the thermostat and see if this changes the chain of events.
Stuart | | |
#66613 09/29/2006 1:17 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Take the thermostat out and place in a pan of boiling water it should open fully in less than a minute and close just as quickly when removed.
When the new stat was installed did you run the engine until it opened and recheck the coolant level.
Sometimes the coolant will drop due to an air pocket in the head finally filling. One way to reduce this problem is to loosen the sending unit to let some air out when filling the cooling system. | | |
#66614 09/29/2006 6:54 PM | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | The radiator fan hasn't been off recently has it? If installed backward it will push air through the radiator from the engine side installed of pulling air from the grille side. It will cool well at idle but heat on the highway, the ram-air effect through the radiator is negated by the reverse air flow from the fan. I have seen this twice over the years with mechanical fans, first time my mistake, second time a customers vehicle. I have also seen this once with an electric fan, wired for a pusher when it should have been a puller.
John | | |
#66615 09/29/2006 8:34 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I just made a little drawing, and it looks like the fan would blow exactly the same way if installed backwards.
Wouldn't the 'pitch' of the blades have to be reversed for it to blow backwards.
Stuart | | |
#66616 09/29/2006 10:00 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The fan will pull the same direction if installed backwards but will not be as efective due to the curvature of the blades. There are fans made to go the opposite direction used with sepentine belts. Check the therm like Kip says or try another one. Iv,e had them defective when new & it will blow your mind. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#66617 09/30/2006 2:08 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | One thing that hasn't been mentioned here is a collapsing rad hose and I think it could also cause this effect. Sometimes a rad hose will flatten with the higher engine speed and deny the engine the coolant flow rate that it needs. | | |
#66618 10/01/2006 12:57 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Sure would like to know which of these, all good, suggestions it turns out to be | | |
