| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Just installed my new wiring harness and NOS junction block. I can't find any information in assembley or shop manual as to what size fuse to use in each accesory or spot. Old junction block had variety of mis-sized fuses I'm sure. Thanks again, Brian M | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Is this on your '27 or your '72? | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you don't find the values in the manuals because any fuses are part of the accessory they fuse - even the fuse panel itself wasn't installed unless there were accessories installed fuse values: backup lites - 9amp heater - 9a fog lamps - 14a park brake alarm - 9a radio - 7.5a spot lamp - 9a under hood lite - 9a
Bill | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Bill, Thanks again. I told my wife that Bill would have the answer. Brian M | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hah! of course there's at least 3 Bills here into TF trucks, easy to make the wife think yer on top of it Bill | | |
