4 members (baldeagle, stlcardinalsguy, Ridgeback, KCMongo), 33 guests, and 4 robots.
Topics128,012
Posts1,055,318
Members48,419
#665883 07/28/2010 6:57 PM
On my new 46 GMC 3/4 ton I just assumed there was a 228 engine in it since it was all original.It was built in Canada so I'm wondering if Canadian GMC trucks used a 216 instead. It looks like a 216 valve cover , can anyone tell me any differences between the 2 engines. Thanks Murray
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
Hydra1/2ton #665912 07/28/2010 8:29 PM
3B Offline
Hy Hydra1/2ton, if you will post the trucks serial number, I can tell you for sure, the 41 - 45 1/2 tons were powered by a Chevy 224 engine, the 46s were powered by a 216 Chevy, hope that helps.
Hydra1/2ton #665913 07/28/2010 8:29 PM
3B Offline
Hydra1/2ton #665950 07/28/2010 11:09 PM
truck serial # is 6942403244 , engine # is x145688
Hydra1/2ton #665954 07/28/2010 11:30 PM
If it is a GMC the valve cover will be stamped in a fancy scrolled GMC....
216 are interchangeable and a direct bolt in....
228 has an external 1/4 oil line in the front of the engine.... none on the 216....
To the best of my knowledge the valve covers are not interchangeable between these two engines..... you may have a 216..... was it original..?? was GMC using 216 due to a shortage...who knows..?
Any pictures available...? where are you located in Ontario??? as I have a spare 228 parts engine..... which was in a Chev and I replaced with a 261.....
BOB
Bob C.
CMP Heaven
The Hammond Barn
RAC1812 #665971 07/29/2010 12:31 AM
3B Offline
Hy Hydra1/2ton, your serial number breaks down as follows,
6 = year 1946
94 = GMC 3/4 ton
24 = pickup delivery 125 1/4" wheelbase
03244 = regular production number
Canadian produced GMC light trucks of this period had Chevrolet engines, yours had a 216 when it left the factory. GMC engines are longer than Chevy engines, so swapping is not a drop in proposition, hope that helps.
3B #666028 07/29/2010 3:41 AM
Thanks for the info 3b , I did not pay much for this truck, but am amazed at the solid body after all this time.(the windows still roll up and down and doors close not too bad). Will try to get some pics of it soon. As for the engine Bob I still don;t have this one free yet and anti freeze came out first when I drained the old oil out so I may be looking for another once this one is diagnosed.Thanks Murray
