1 members (Stovebolt48), 71 guests, and 3 robots.
Topics128,056
Posts1,055,803
Hello Everyone,
I've got a question about the hood spring removal tool that Kieth Hardy and Chris Taskos discussed in the Tech Tip. The diagram shows the measurements for a 49-54 chevy hood tool, I'm interested if anyone might have the height measurements for a 58 apache hood, I can't imagine that they would be too different, but I am not familiar with the hood springs from the earlier trucks. Any help would be greatly appreciated
Ex Hall Monitor
Ex Hall Monitor
Shoot, all I ever used was a large screwdriver and a good helping of caution.
you might try measuring yours wink not sure that technique would work on the 58 with the springs mounted so differently, but they're about the same length overall
first remove hood, makes it a lot easier - otherwise find a stick a length to hold the hood up as far as it'll go, the spring isn't totally relaxed when open .... put a pair of vicegrips on the front spring hook - using a good pry tool [big screwdriver] poke in behind the bracket it hooks in and pry the end forward and out of the slot
to put it back, use the vicegrips and a strong arm, or maybe 2, not too tough actually
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I made & used THIS to install & remove hood springs.
And if you need to spread the springs apart try it THIS way..joe
Zookeeper, that is a fine idea. I have copied both of those photos for future reference. I had been wondering how to better reinstall the hood springs on my project 66 C-1. Thanks!
Seth K. Pyle
Nothing is sailor-proof...
1966 C-10 SWB 327 - 700R4
Story in 60-66 Parking Lot
Hope this helps.
Just changed the hood springs on my 55 series 2.
If you look at the springs when the hood is open, they are closed. That is to say no gaps between the spring coils. On the other hand, when the hood is closed the spring stretches and there are gaps.
Lower the hood just enough so you can reach in and push 6 to 8 washers into the gaps. Then open the hood. The springs with washers will fall out of the hinges.
Install the same washers in the new springs. I used a chain hoist and stretched the springs with two tow ropes and the bumper of my SUV. Then open the hood all the way and put the springs with washers in place. When you close the hood the washers will fall out and the springs are "installed". EASY, and only takes about 15 minutes.
