| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Small block chevy - Mechanical fuel pump. Had some flooding issues last week. When working on system, I noticed that I have air bubbles showing in glass fuel filter when motor is running, and that filter is only about 2/3 full. Gas tank is under the seat - gravity flow from bottom of tank to pump. All that being said, motor runs strong / no issues. Am I worrying about nothinh here or do I have a fuel pump that is going ? Thanks Guys. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | normal condition, the filter is never full, bubbles expected .... fuel pumps either work or don't work, be real odd for one to be sucking air without showing up a gas leak when off
Bill | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Might also check your fuel line routing, if it's too close to the engine it could be boiling the gas. It depends on how much Bubbling you have in the filter, if it's a lot like a pot of water boiling on the stove then check your line routing. If it's just a little then it's prob. normal. Mongo | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | | | |
