1 members (baldeagle),
69
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | When AD trucks came from the factory the line where the interior and exterior color broke was not a hard, crisp tape line but rather a soft transition as one would expect from using a reusable loose fitting "plug" to fill the door opening when spraying the exterior color.
I have no intention of making such a plug just to achieve such an insignificant result but if anyone knows of a masking method that would yield the same appearance I'd appreciate hearing about it. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Woody, A nice video here That explains and works well. Dan | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Woody,
We taped and masked with brown paper the interior from the exterior (after first painting the interior) by taping at the edge of every exterior opening at the edges where the exterior skins ended. All exterior edges are over the interior pieces of sheet metal, except at the window openings - just mask at the inside "pinch joint". I forget how we exited the cab after taping the last opening (probably out the bottom?).
We'll be doing this again on at least one cab by the end of the summer (I hope).
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I have found the easiest way to mask a soft edge is simply apply the tape centered over the desired line. Then simple roll back the tape along the length. This method deflects the air/paint and prevents the hard edge from forming | | | | | Joined: Jul 2008 Posts: 17 Apprentice | | Apprentice Joined: Jul 2008 Posts: 17 | I use the roll back method also | | |
