4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#66384 09/24/2006 9:41 PM
I am pulling the 283 out of my 65 and putting in a 350... will I have to swap the bell housing too. Also, the 350 is coming from a 79 Chevy 3/4 ton that has power steering... I noticed the frame for the 65 is already "predrilled" for bolting on the gear box from the 79. By predrilled I mean that there are already holes in the frame that would make it very easy to bolt on the other gear box or at least it seems to be very close anyways. I have looked over both set ups very closely and I am wondering if the gear box from a 79 would easily swap out and if so, do I have to make any mods beyond that point in order to get power steering on my 65.
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
#66385 09/24/2006 10:29 PM
Riding in the Passing Lane
The 350 will bolt right in to replace the 283. I,m getting ready to do it on a 58. The best way to mount the power steering gear is to get the kit that most aftermarket supplies sell. You can mount it but it doesn,t fit right & you have to stack washers between the gear & frame. I don,t remember what pitman arm you use but the direction sheet with the adapter tells. Your column should bolt up & you might have to bend the tubes on the hoses.
1972 Chevy c10 Cheyenne Super
#66386 09/25/2006 6:24 AM
get the kit.use the arm from the new box.
64 c10
89 rs
62 econoline
50 ford coupe
#66387 09/26/2006 4:07 PM
Junior Member
Junior Member
pm sent to ya bowtie
