| | | Forums66 Topics128,117 Posts1,056,642 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | Would like to not break the bank buying rear drop springs for my 1962 1/2 ton GMC. 3" drop is what I am looking for. Any suggestions?.... Thanks | | | | | Joined: Feb 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 38 |
The glass is twice as big as it needs to be.
| | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | I've heard of using newer jeep wrangler springs. Saw a post somewhere. They're identical I think. Find the local jeep place that does jeep lift kits. Bet you can pick some up cheap. I remember vaguely the poster said they were 10 bucks. | | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | So is a 63-67 rear spring the same as a 62? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I purchased my springs from CPP. Don't buy them from LMC... they buy them from CPP and mark them up a $70 bucks a pair! Learn from my mistake.... https://www.stovebolt.com/ubbthread...;Words=emptor&Search=true#Post495875The "Jeep" springs sound scary. Never heard of a half ton hauling capacity Jeep Wrangler. When it comes to suspension components, steering and brakes its best to belly up to the bar and buy components made for the specific vehicle, IMHO.
| | | | | Joined: Oct 2009 Posts: 15 New Guy | | New Guy Joined: Oct 2009 Posts: 15 | I got mine from CPP. They have really good customer service and technical support. They usually are a little bit cheaper then Early Classic Enterprises too.
Something you might think about. You could cut half a coil on your stocks spring and get 2 inch lowering blocks. That would get you 3 inches of drop and cost about $70 bucks.
How do I know so much about these trucks? I stayed at a Holiday Inn Express last night.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bet you are right about the jeep springs not having the capacity, but it prob won't have much hauling capacity after a 4" drop either. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | The local brake and spring shop here cut the spring or heated it on my brothers truck .I heard all the bad stories from everyone not to do it, but they knew what they are doing and he loves it .Its been 4 or 5 years now .He also still uses his truck for towing and hauling. | | |
