4 members (Otto Skorzeny, Philipj, 60steve, Greg '46), 67 guests, and 4 robots.
Topics128,181
Posts1,057,151
Members48,464
My 40 truck has an ignition switch that has a large spring behind the dash keeping tension on the chrome ring going through the dash. How do I remove the switch? Does the chrome ring turn? I don't see any flats when I push the ignition switch forward to expose the area behind the outside ring. I don't want to break it if it is not supposed to turn. There are no holes in the switch to put a paper clip into to remove the tumbler, but I just want to remove the whole switch from the dash. Thanks.
Ex Hall Monitor
Ex Hall Monitor
If it still has the electrolock it might have two screws that you access from the back side of the dash (at least that's how my 38 is connected).
I find no screws behind the switch. There is a large spring that if you push from behind the switch, the chrome bezel comes thru the front of the dash to reveal a smooth round part of the bezel. It apears like it should turn to unlock it from the body of the switch, but no flats are on this round area. The bezel has acc, off and start, but no hole for a pin release in the tumbler area. I have not seen one like this.
Ex Hall Monitor
Ex Hall Monitor
Sounds like someone has put a different switch in. I believe the '40 originally had an electrolock (armored cable from the switch to the top of the coil). If you have a digital camera a pic or two might help us help you.
hopefully this connection to pictures works. This shows my ignition switch.
photo bucket of my 40 ignition switch
Ex Hall Monitor
Ex Hall Monitor
Sure different than my 38. Sorry I won't be able to help you. Someone else here most likely can. Good luck with your project.
