6 members (Millenimech, Gib70, Hotrod Lincoln, Steelonsteel, Gray_Ghost, 1 invisible), 149 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#662815 07/16/2010 1:43 AM
Apprentice
Apprentice
this probly seems like a stupid question ,but i have been banging for hours on this front drum trying to remove it. i pulled the rim off and just started banging and spraying wd40 letting it soak and banging some more. my question is, is there anything thing else to do or if you have any suggestions. it is a 64 chevy 2wd 6lug. any help will be very appreciated.
alan
You can adjust the brake shoes in and maybe open the brake bleeder. If ya open the bleeder you will have to make sure to get all the air out of the lines before driving again.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Apprentice
Apprentice
well right now i dont even have any brake fluid in it. any other suggestions. thanks
Does it spin or is it seized in place?
Apprentice
Apprentice
i can spin the drum and everything moves with it. this truck has been sitting about a year.
Alan:
Usually the fronts are easier than the rears since you can remove the nut on the spindle, remove the outer bearing and have some play back and forth with the drum once the bearing is out. If that still doesn't work, you can try removing the bolts for the wheel cylinder from the backing plate to let the cylinder slide out with the shoes. Also, you can drill out the two locating pins from the shoes from the back side of the backing plate. One or a combination of these should get the drums off. If the wheel is still turning, you should not be having such a tough time.
I hope this is helpful.
regard,
Steve
New Orleans
The hub and drum are riveted together.There are 3 rivets centered between the 6 lugs. Some people grind them off and remove them so the drum can be removed without pulling the whole hub assembly off. Pull the dust cap off and remove the cotter key and remove the big nut. I use a crescent wrench. Pull the whole thing outwards. The bearing will slide out. Go slow. don't drop them on the floor. Just so you know.On the back brakes the drum slides off like normal.
Apprentice
Apprentice
If I grind those off, are they ok being off or do they need to be replaced?
Apprentice
Apprentice
i appreciate your help i ground them off and removed the nut and separated the drum from the hub so next time i wont have this problem. thanks again.
alan
Glad to help. As a side note. Some people grind them off but don't remove them completely. The drum will still be hard to get off. I've heard of ground off but not removed rivets vibrating out and wreeking havoc on the drum internals.
