5 members (Ponchogl, walter74, 55shaker, ronsway, 1 invisible), 179 guests, and 9 robots.
Topics128,089
Posts1,056,138
Members48,435
#662185 07/13/2010 9:49 PM
1962 gmc 4000 fire engine with a 351 V6, NP540 5spd trans and a 7.20 axel ratio. The tires are 9.00X20 39" tall. anybody know the top speed? It only has 18,000 miles and everything is in great shape.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #662299 07/14/2010 3:58 AM
Unless fifth gear is an overdrive, I'd bet that ole engine would be screaming at 45mph. Also that v-6 is not made for high rpm use, it is a torque monster by design. let us know how it goes!
And how about this one?
A 261, and 4 speed, 2 speed rear... what can be the guessed top speed?
The same ? 45 mph ?
http://i185.photobucket.com/albums/.../BpHpPuQmkKGrHqQH-CwEuYw1oB-IBLqBeob.jpg
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
I dunno about it screaming at 45, seems a bit slow for a 7.2:1 final drive to me. However it wouldn;t be the 1st time I've been acused of being a [censored]. :P
Just saying, my old dump, in stock configuration, with a 10/8.5:1 2-speed rear, & same size tires, will do 50-55 all day long.
By my calculator, taking the tire diameter and R&P ratio given, if your 5th gear is 1:1 you should be running around 48 MPH at 3000 RPM, and if you have the 0.82:1 ratio you should be running 59 MPH at the same RPM. There are around 9 sets of gearing for the NP540, but from what I have found 5th gear is one of those 2 ratios.
With that information, the question then becomes what's the RPM limit on your engine, or, at what RPM does the torque drop off. Given that number & I can tell you approximately what your top speed will be in each gear.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Two speed rears in our old trucks only give you lower gears to work with, they do nothing to help top speed. They are just there to help the small engines pull larger loads. The top speed will still be the same regardless of 2-speed or not. Like Freq2002 said, mid 50's is about as fast as they go in stock configuration.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Grigg #662367 07/14/2010 1:52 PM
Just click the link and plug in your variables, it spits out the answer.
There is no guessing or speculating, it's simple math, and simpler with the above link, just plug and play.
Grigg
---All pictures---
Grigg #662434 07/14/2010 8:26 PM
When I put in the numbers, I got 48 mph at 3,000rpm also. From everything I've read, the V6's are torque monsters that turn into bombs at high rpm's. I'm going to put a tach on it because I think it sounds faster then its really going. thanks guys.
Not sure what gears it had, but my '62 6500 with a 478 V-6 would go 62 MPH. I believe it was governed, but at that speed it didn't seem to be over-revving and still had plenty of power.
That was just for short distances tho. I don't think I would want to drive it all day like that.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
I looked at the data plate again and got more info for the trans- np540 type GL speed 5DD. does the GL or 5DD help to find the 5th gear ratio? thanks
5DD to me means 5th gear is Direct Drive (1:1)...can't help with the "GL".
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Your New Process 540 is direct drive in 5th. Good transmissions, rather unusual shift pattern, at least for me. James
1957 Chevrolet 6400 flatbed dump
Webshot pix
1942 Chevrolet 1 1/2 ton
1962 Chevrolet M80 tractor
thanks guys.
Couldn't find anything on an NP540 with a GL suffix. However I found a couple references that say the '57-'69 NP541GL transmission should have the following ratios:
1st 7.24
2nd 3.88
3rd 2.19
4th 1.37
5th 1.00
7.22:1 R&P
Oh, and if anyone wants it, and ya have Microsoft Excel, I can email ya my engine/transmission calulator.
Allows you to figure exact displacement (numbers are plugged in as mm’s but gives results in Metric and SAE), compression ratios, & camshaft data. On the 2nd tab, it gives speeds according to tire diameter, R&P ratio, gear ratios up to 5 gears. You just plug in your shift RPM/redline for each gear and it will give you your top speed for each as well as the approximate RPM at bottom of next higher gear. I made it for building engines & figuring gears for drag racing to keep the engine in the top of the torque curve. Still pretty handy for fun questions like these.
:P
James, what actually was the shift pattern? Was Granny 1st to the right down and Reverse to the right and up?
GMC 9500 Fan
Detroit Diesel Fan
First was toward the driver and toward the dash. Second was right next to it. Reverse was away from the driver and toward the dash. Shifting between first and second was rather awkward.
That does seem awkward. The trans I was talking about was:
2 4 R
3 5 1
It was a long way from 1st to 2nd. It also had a 2-Speed Rear and the sequence was
1L
1H
2L
2H
3L
3H
4L
5L
4H
5H
GMC 9500 Fan
Detroit Diesel Fan
Bill, the New Process shift pattern was just like crenwelge mentioned and it was awkward...
1 - 2 - 4 - R
- - 3 - 5
For us in the dump truck business it was hard to 'rock' a mired down truck, going from reverse to 1st or 2nd quickly sometimes meant clashing gears and missed opportunities to move forward, at the same time we dug a deeper hole.
The Clark transmissions that we used were somewhat better, there shift pattern was...
2 4 R
3 5 1
My favorite were the Spicers...
R 2 4
1 3 5
A driver could quickly go from reverse to 1st or 2nd without a lot of effort. Reverse and 1st were spring loaded on the shift lever. These were the shift patterns that I'm familiar with these trans, but I imagine Spicers may have used other patterns. We favored the Spicers on our Chevys from the late 50's thru the early 70's, when we wore out a Clark or NP it was replaced with a Spicer.
Just my 2 cents worth, James
Webshot pix
Top RPM's on the V6 is 3600 we max ours out at 3200.
ABento #663340 07/18/2010 10:55 AM
OK, so if you take the RPMs ABento said and the gear ratios I listed for the NP541GL, shifting at 3500 for 1st thru 3rd, 3200 for 4th, & cruising at 3200 in 5th, your approximate speeds should be as follows:
1st: 7.8MPH @ 3500RPM
2nd: 14.5MPH @ 3500RPM
3rd: 23.5MPH @ 3500RPM
4th: 37.6MPH @ 3200RPM
5th: 51.4MPH @ 3200RPM
And just for giggles, at redline, 3600RPM, in 5th, you should be pushing 57.9MPH
And looking at this, I really need to get my RPM guage hooked up and working,... If I have a 8.5:1 high range and a 1:1 trans, AND I can run at 60?... My lil 270 must be spinnin at about 4500RPM. Yeesh! grin
:P
