6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#661521 07/11/2010 3:30 PM
has anyone had experience with the metal cutting circular saw from tractor supply? my torch work has never been that great anyway & i'm tired of grinding.
robert
Robert French MY3800FIRETRUCK
I used my Skil saw with a carbarendum metal blade, like a chop saw blade. It worked good a little slow but it worked. I cut sheet metal to fab the inside pan of my 68 jeep.
Nope, I use the hand held Dewalt grinder with a cutting wheel/disc. Works good and gets in some tight places o.k.
Hank
If you are having trouble cutting a straight line try clamping a piece of thick flat bar to the metal and run the torch tip along it, if you want a dedicated "burn bar" grind a 45 degree angle on the bottom edge so the slag wont cause the tip to jump might consider a handle from some 1/2" round. I put a 1" spring on mine then bent the ends down about 6" keeps from burning my hand from heat transfer. I used about 2' of 3/4" F B 3" wide. The heavy bar doesn't move. Clean up isn't to bad with a good straight cut.
You Learn more Listening than Talking
A nice metal cutting band saw is my perferred method of cutting thin stuff.
Moderated by  MNSmith
