5 members (Waveski, Phak1, Guitplayer, 54farmtruck, MickeyP), 49 guests, and 1 robot.
Topics128,188
Posts1,057,332
Members48,469
My donor 235 used to swap out for the old 216 is a 1956 235. It did not have the rocker tube oil connector that goes from the oil journal above the rear cam journal to the oil journal that will supply the rocker arm assembly. This is the oil line inside the the rocker arm cover. Question is, did anybody buy one pre-bent? If so, where did you purchase? If not, what size brake/fuel line did you use? Thanks for your time,
Hank
1951 restoration on website
http://www.hanklong.com
There is a 3/8 reducer on each end down to a 1/4 line. Just wanted to post the answer in case anyone runs into a simular problem.
Hank
