| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | has anyone had experience with the metal cutting circular saw from tractor supply? my torch work has never been that great anyway & i'm tired of grinding. robert | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I used my Skil saw with a carbarendum metal blade, like a chop saw blade. It worked good a little slow but it worked. I cut sheet metal to fab the inside pan of my 68 jeep. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Nope, I use the hand held Dewalt grinder with a cutting wheel/disc. Works good and gets in some tight places o.k.
Hank | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | If you are having trouble cutting a straight line try clamping a piece of thick flat bar to the metal and run the torch tip along it, if you want a dedicated "burn bar" grind a 45 degree angle on the bottom edge so the slag wont cause the tip to jump might consider a handle from some 1/2" round. I put a 1" spring on mine then bent the ends down about 6" keeps from burning my hand from heat transfer. I used about 2' of 3/4" F B 3" wide. The heavy bar doesn't move. Clean up isn't to bad with a good straight cut.
You Learn more Listening than Talking
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | A nice metal cutting band saw is my perferred method of cutting thin stuff.
