3 members (TexasA&M48Truck, TUTS 59, Barney1951), 84 guests, and 4 robots.
Topics128,191
Posts1,057,224
Members48,465
U
U Offline
Is it possible to fix this? This is the front right fender brace for my 57 Chevy truck. Vice or heat?
Thank you!
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
no heat necessary, just grab the ends, put the bend against a solid surface and bend'er back [if necessary, use pieces of pipe on the ends for more leverage] - once straighter you can put it on the concrete floor and rap it to perfection with yer BFH
U
U Offline
Cool I will give it a go today.
Jon
More pix
U
U Offline
Bill,
Got'er fixed .
Next question:
Is it worth fixing this ? This is the for the rear passenger side fender. The brace screws into the frame. Or just break down and buy a new or used one? new about $45 pair. old $22. I do not have a welder. to fix.
More pix
thumbs_up finding someone to do the welding should be cheaper than used [or maybe someone here would donate one], just need to get a bolt the right size, slightly longer than the broken off threaded end, cut the rod back clean, and have it tacked on, 2 minute job .... bring'er by, I'll do it grin
