| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 11 New Guy | | New Guy Joined: Nov 2009 Posts: 11 | what rear diff is in my truck... its a 1962 chevyC-10 235 I-6 w/ 3 speed manual the rear diff is very odd seeing that it has both a third member and a rear cover.... need to know what model diff it is so i can get a new pinion seal truck is not drivable at this time because it will not hold fluid any info is greatly appreciated... thank you | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Eaton HO 33. Same rear was used from '55-'62.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 11 New Guy | | New Guy Joined: Nov 2009 Posts: 11 | Does any one know where i can get the seal from having trouble finding one for it | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any parts store should be able to get it for you, though they may have to order it.
Bill Burmeister | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I got my seals from The Filling Station. My local Napa couldn't look up one for my truck based on year/model and stuff, and I didn't have the old one out yet to look it up by number.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
