6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#660221 07/07/2010 1:31 AM
I have been studying the wiring diagram for my 53 3100. It appears to me the low beam circuit stays on all the time once the switch is pulled out fully and the dimmer switch only controls the high beam. Am I correct?
Thanks in advance.
the lights are on alla time when you pull the switch, the power from the switch goes to the dimmer, which routes the power to one or the other filament, bright or dim .... note that the dimmer switch has 3 wires, one from power, one to the low beam filament, one to the high beam filament
Squeeze
Thanks for the info.
Dan
