9 members (farmallb, JW51, Barney1951, klhansen, Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, 1 invisible),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 7 Member | | Member Joined: Feb 2002 Posts: 7 | I've pounded, crowbarred, and everything else I can think of to get this #$$@& oakie bushing in place and still can't get the last part of it in. (Yes, I've pulled the old seal out, and yes, I am using a piece of wood for direct contact with the Oakie Bushing.) Am I missing something obvious here? THe instructions say to set it flush. Doesn't say flush with what, but I presume just past the splines of the drive shaft. Already tried using the old Yoke as a guide, but that just slips in underneath the bushing. Or is supposed to be that way? Mike 51 3100 http://nogrownups.tripod.com/Mikestruck.htm | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey Mike,
Refer to my reply to your other torque tube question. The new bushing should be flush with the end of the tube itself when fully seated. When I installed mine, I removed the old bushing, cleaned and inspected the driveshaft and tube,and drove the new bushing in place.
Yes, its a cast-iron biznitch to install. It has to be a tight fit so it doesn't rotate during use. Some models had a rivet or a dimple in the tube housing to hold the bushing in place. Make sure that isn't your problem.
Use a 2x4 and a hammer to drive the bushing flush with the driveshaft. Then I used a thick wall, deep well socket to drive it flush with the tube housing. Ironically, the only thing that was a perfect fit was a socket for removing the big nut from a CV axle in a FWD car.
Just be careful and it will drive into place
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
