0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65996 09/19/2006 2:00 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | OK , Lets see if I can get this right so I can get the anwsers that I need to make the right choice in the parts that i need. Frist off I'm a mechanic by trade , have been since the late 60's . I remember pumping gas for 21 cents a gallon in the mid 60's in N.J. My frist taste of cars and it has just kept on growing. I've got a 65 c-10 custom cab short bed that I've owend for about 12 years. Non power anyting. I want to add p.s , power disc brakes to it now. I just bought a 82 silerado long bed with a 6 cyl. just for the front end swap , but after I drove it home I knew it was in too good a shape to make it junk if I pulled all the front-end parts off of it. It runs and drives great. I keep a new Tahoe or pick-up (trade every 2 years) and have a company F-550 service truck for getting around so transportion is not an issuse. I only paid $300 for it and really want to keep it in one piece.So now I need another doner truck. I found a 75 c-10 w/ disc brakes non power and p.s . Will this year swap into my 65 and if so what other parts might I need to do so ? Thanks for everyones time and input George Hood
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
#65997 09/19/2006 2:14 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You can use the entire front crossmember from 71-87 to get disc brakes, any steering box from 68-87 will fit using a REZ kit or equivalent,,Brian | | |
#65998 09/20/2006 1:06 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Brian, Thanks. Jim thank you too , I got your E-mail . How about the brake booster? My 65 is non- power as is the 75 . What sort of booster can I mount to the 65 ? and not run into a clearance problem.? I"m not a newbie to restoring /rodding cars an trucks but I'm in a area now that I've never had to do and like Jim said in his e to me , " why buy a high doller kit when there is other stuff that will work, and just as good" Sorry Jim added some words in there to make my point. Gentleman , Thank you for all and any information . Ineed it . George Hood
#65999 09/20/2006 2:02 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used a booster from the 1980 C10 I got other stuff off of, what is surprising is two mounting holes on the booster linde up w/OE master cyl mounts, I just marked the others & drilled. Brian | | |
#66000 09/20/2006 2:38 AM | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | 64 f.the booster i looked at had a seven" rod. my 64 needs a nine" rod.did i miss something?
64 c10 89 rs 62 econoline 50 ford coupe
#66001 09/20/2006 2:53 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | On mine I used the two rods together using the threaded sleeve off the 64. I cut the 80 booster rod off(after figgering the right length) & threaded it, then used the 64 sleeve & pedal end. I had forgotten about that part as it has been a coupla years or so. Brian | | |
