7 members (baldeagle, Southerntruck, Hanks custodian, Woodcmiami, J Lucas, Rusty Shackleford, TooMany2count),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,133 Posts1,056,398 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm street rodding a 57 Cameo. I've gotten to the taillights. I'm having trouble finding a wiring harness for the backup bulbs. It's either for a #1156 or a #1157 bulb. These have to be available. Any idea who or where? Thanks, regmudd | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Unfortunatly, the oem backup lamp harness is not be reproduced. The harness itself shouln't be too hard to make, single contact sockets (1156 bulb) are readily available, the rest of the harness is pretty straightforward. If you're still using the oem style switch, it takes the bullet style ends, the small size IIRC.
Bill Burmeister | | |
