3 members (68ironhead, Otto Skorzeny, Jerry 53), 72 guests, and 2 robots.
Topics128,094
Posts1,056,489
Members48,444
I was cleaning up under the cab before I weld in a new floor pan and found some numbers stamped on the frame. They are on the drivers side, right under and slightly behind the front cab mount. Its not the VIN, anybody know what they are and what they mean?
Here's the numbers:
3881391 120 5 19 113
Pretty sure part of that SHOULD be the VIN. Is your cab and frame original?
The glass is twice as big as it needs to be.
The VIN stamped on the frame by the engine matches the one on the cab. The number under the cab doesn't have any elements in common with the VIN.
Yeah... I remember that from mine a while age now. Maybe they are like the "buck tag" on other cars n trucks. Has to do with factory options and assembly line info.
