1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#658079 06/28/2010 5:34 PM
just finished the restore of my '56 3600.
new wiring, lights and aftermarket turn switch
when I press the brakes the left turn indicator,left lamp and right brake light come on. With the brake off the turn lights work properly.
I have checked grounds and bulbs
I am suspecting a bad diode or crossed wire in the switch,
your thoughts?
no diodes involved in anything 1956, most likely wires wrong at the connector where they come out of the column, or much less likely, a defective new switch - see the wiring diagram linked on your other post
I should have stated this is not a stock cup type TS switch, it is an aftermarket 7 wire switch
here
http://www.brotherstrucks.com/prodinfo.asp?number=TSA7200
then look in the tech tips, there's a good aftermarket signal article there, still likely a wiring problem, checking if that's all correct will be needed before suspecting a defective new switch .... and still no diodes involved smile
I had a similar problem when rewiring mine, had one wire crossed and took 5 min's to locate w/ diagram in hand.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
If you have dual filament bulbs replace all. A friend of mine had a similar problem and it turned out to be a bad bulb that had the top filament break and weld it self to the bottom filament and cross connect the circuits.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Sir Searchalot
Sir Searchalot
I had the exact same thing Hippy is talking about. Look at the bulbs carefully.
I figured it out,kinda,
after realizing that the indicators, because of the brake light circuit,flash off of the front turns,I just switched the LF and LR wires, works great!
I am doing a homemade wiring harness for my custom 53 3100. I have studied the posts on the search feature and the tech tips as well. I found wiring diagrams on later model vehicles but there is still one thing I do not understand. How does the brake light circuit integrate into the turn signal switch without causing the power to feed back to the front turn signals as well? Is there an internal diode in the switch to isolate the front? I understand circuits and basic electronics so there is surely a more clear explanation for this. Since one post said there is no diode in older systems how did they do this? Thanks in advance.
mechanical switching Dan - when no direction selected, the brake power goes straight thru the switch to the rear, when a direction is selected the brake power for that side is routed thru the flasher so that it's interrupted .... of course that means you'll have to wire your lights as the newer ones are done, this 5-9 diagram may help .... study Cletis' tip a bit and it should come clear - there's no connection between the brake and park circuits except when both lights on one side are blinking
