7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Hey fellow Bolters. I've been running a pair of carter weber carbs on my 235 for some time now. They have been working great untill the other day. After the truck had been sitting for a couple weeks I went out to start it up and found that the rear carb was flooding out. It wouldn't run worth a darn and was leaking gas onto the manifold. I took the air cleaner off and found a puddle of gas sitting on the butterfly of the secondary. I haven't had a chance to tear the carbs apart but it seems like the needle valve is stuck and flooding the carb. I'm not too sure how crud can get into the carbs. I have two new fuel filters in the system. One before the fuel pump and one just in front of the carbs. Has anyone had this problem with the carter webers? Any advice would be most appreciated. Thanks George | | |
