2 members (Ponchogl, Shardean), 85 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#656778 06/23/2010 3:45 PM
I have my 235 stipped down to a short block. The head that was on it has cracks around the exhaust valves in three out of six of the cylinders.
I would like to check the main bearings. Can I just take off the caps and check for scratches and wear? I have a tendency to go to far. I would like to keep the block intacted but still check for problems. Any suggestions?
Thank you
3B Offline
Hy Chuck49, please remember to tell us what year engine/truck you're asking questions about, there are differences in construction/bearing adjustments throughout the years. You can simply remove your caps and check your bearing condition, if they dont appear too bad, and the crank looks good, then you could plastigauge them and check the clearances. If your clearances are a bit too large, and you have an earlier shim adjusted main bearing block, you could remove shims to adjust your clearances. If your block is a true precision bearing block [no shims] and your clearances are too large, then I'm afraid you have to turn the crank and purchase the appropriate oversize bearings. If you do have a shim adjusted block, and it needs a total rebuild, I would highly recommend having the block align bored, hope that helps.
Thanks. It's a 56 and supposed to be a full-flow. The engine came out of a 56 Chevy sedan, and it's in my 49 Chevy 5 window 3100 truck.
What should the plastiguage read?
Thanks, again! Chuck
3B Offline
Hy Chuck49, the clearance on the main and rod bearings for that year 235 is .001" - .003", hope that helps.
Chuck,
Use the green plastiguage.
Hank
1951 restoration on website
http://www.hanklong.com
Here's a link that has helped me with my '56 235 rebuild as well.
http://www.secondchancegarage.com/public/373.cfm
It has all the spec's , torque, clearances, etc. Good luck with your project.
Thanks, guys! I REALLY appreciate all your help and suggestions! Have a great weekend! smile Chuck
