| | | Forums66 Topics128,034 Posts1,055,542 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Just trying to find out what everyone is using as a standard size brake line. I was at the store last night to pick up some and they have 1/4" and a smaller size. I held off to go check what is on the rear that I installed and it was smaller line the the original stock that came on my 52 Chevy. I am adding an under the floor booster/ Master setup and when I checked the extra one that I have I realized that they used the 1/4" on some lines and the smaller on the other. I think the other size is an 1/8" or they are 5/16" and 3/16" I cannot remember off the top of my head. Is there a one size for all or at least a guideline for what to use? Thanks | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Forgot to mention that I have a disc brake setup now in the front also. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 3/16 and 1/4 are the two common sizes used on brake systems, it varys from system to system. Some use all one size, but many use a mix. Since you're running an aftermarket brake system, OE sizes won't really matter. Sounds like they have it setup for 1/4 to the front, 3/16 to the rear.
Bill Burmeister | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | I have a aftermarket set up on my 49..Disc front ,drum rear...I used 3/16 up front...1/4 to the rear which goes into a rubber hose and tee,then 3/16 to each rear wheel........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Disc needs more fluid volume transferred to move the piston, hence the larger line. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Fluid volume doesn't necessarily relate to pressure. Most aftermarket (front) disc conversion kits use 3/16 front and 1/4 to the rear. You will find that the proportioning valves are designed for 3/16. I have installed numerous kits on a variety of vehicles and have not had a problem with this configuration. Fred
| | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | rfs56trk, that is correct it's more about pressure transfer, there's very little fluid movement. most modern disc brakes use 3/16 hard lines. i think the only reason ( & this is just an opinion ) that some ran 3/16 to the front & 1/4 to the rear was to avoid confusion. robert | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | I was planning on going 3/16 all the way around based on the comments and I know the rear that I have in there used 3/16. Thanks for all the great input that's what I was looking for. Now I can move forward on the project. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | there's very little fluid movement
Except for that... pedal thingy, and those little whatcha-ma-callit caliper pistons. Where does that motion go? Fluid always moves. Disc brake calipers require more volume transfer than drum brake cylinders. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've seen them both ways on the OEM brake systems.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | 3/16 going to the front is a smaller line then 1/4 or 4/16 going to the back. If Discs take more fluid to opperate, then that meams more fluid would move farther in a smaller line then a bigger one. Fluid only moves if it has some place to go. If one side of a wheel cyl is froozen up, the brakes will only wear on one shoe and will not on the one side that is froozen up. That happened to me. I needed to replace the wheel cyl all the bolts broke off. The 2 mounting ones, the bleeder and the line bolt stripped.
I will be replacing with a dual 7 in power brake booster and replacing all my lines. I have a 53 long box truck with a newer 14 bolt 3.75 ratio rear end. I do not know what size my lines are at the master cyl, or what size I should use on the rear end etc etc. Also I want to change from the right side to the left going to the back and change the mounting braket to the flexable like to the rear end. Has Any one done this to there truck? Let me know.
Gerry | | |
