7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible),
92
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I'm rebuilding a Carter updraft carb for my COE. I've got the carb apart and it is missing the step up piston. I took the step up plug off and I have the spring, but no piston. Is the piston metal or another material that would deteriorate? Where would I find another. Help...
| | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Check out this link. http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm634.htmIt's a down-draft carb but the pumps are the same I would think. A new pump, (piston), should be in a rebuild kit. It's metal with a soft seal attatched to the disc at the end of the flat metal shaft, forming a piston. Hope this helps. Jacques
Union, Justice and Confidence
