5 members (fonz8261, dt235sd, klhansen, greenie-reddy, Opelika Tom), 100 guests, and 3 robots.
Topics128,078
Posts1,056,283
Members48,441
#65531 09/11/2006 1:53 PM
I just pulled the hubs, and the axle, and the springs from the front of my 1958 1 ton. It has the ball bearings. Several of them are badly galled, so I'm gonna replace.
I see there is a upgrade available to change over to taper bearings (see link). Anybody ever do that to tell me how it worked out?
http://www.americanclassic.com/asp/...;iyear=1956&ytype=to&exyear=1956
What else should I change while I've got the hub taken apart this far? Oil seal for sure.
Thanks.
King pins are only 40 some bucks from Carters....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
Junior Member
Junior Member
I just converted my '51 1/2 ton from roller bearings to tapered. I recommend it very strongly. The steering is smoother and I have no doubt it's safer. I'm not sure about the availability for 1 ton. Check Brothers and the company that used to be Chevy Duty, Classic parts of America. The latter was $125 for my truck, cheaper than Brothers.
Hope this helps.
John Morris
Washington, Vt
Junior Member
Junior Member
What I meant to say was I switched from ball bearings to tapered.
MtManVt,
Did you have any luck finding the boxes the bearings and seals came in. Sharing those numbers would be great.
Stuart
Junior Member
Junior Member
No Stuart, I foolishly chucked the boxes. Or I should say my girlfriend threw them out because they weren't nailed down. That's why I didn't respond to the previous posts. I tightened the new tapered wheel bearings down to original factory specs. (I think it was 33 ft lbs) and they were a little tight. The drum dragged a little. I loosened them up and they work fine. They are part #73-061K in Classic Parts of America.
http://www.classicparts.com
