2 members (MNSmith, Otto Skorzeny), 92 guests, and 2 robots.
Topics128,130
Posts1,056,717
Members48,454
I have the granny gear 4 speed , and want to remove the speedo drive gear to see what is going on in there.
The coupling has a 15/16" hex. I tried to unscrew it, but it is very tight. It moved, but it took a lot of force to just budge it a little.
Before breaking anything, I thought I'd check here. Is it OK to unscrew that part to get to the drive gear?
Yes, it unscrews. I had to use the socket nearly all the way out on my '54.
ok, thanks, I'll just crank on it later
