4 members (DBJ71SuperCustom, Gdads51, UtahYork, 1 invisible), 102 guests, and 4 robots.
Topics128,191
Posts1,057,364
Members48,469
i have a 78 camaro with disk rolling frame. has anyone herd or done this?
The only usable part will be the front subframe, as the Camaro is a unibody and doesn't have a full frame. It's a cut and splice deal. Another option would be to get a weld in crossmember that uses the Camaro suspension and brake parts, which will eliminate cutting the front portion of the stock frame off. You can get those crossmembers without the suspension parts and use the ones you already have after rebuilding.
Bill Burmeister
Y
Y Offline
Are you thinking about "subframe" clip? Check out this web site
http://www.chevytrucks.org/tech/index.htm
http://www.bunchobikes.com/clip.htm
nice thanx
