8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65402 09/07/2006 3:53 AM | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | How can I line up the front of my 235 to install front motor mounts with only a jack ? The old one came loose & the motor is about 3/4 " over to the drivers side at the front. Thanks, Kelly 53 3100 http://www.cravy.com/53-3100/LadyAfterRats.jpg | | |
#65403 09/07/2006 4:21 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my thought: 2x4 on 2 jacks, motor on the board can be moved side to side with a bar .... a biiig bar - otherwise rent a transmission jack with wheels Bill | | |
#65404 09/07/2006 9:51 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
#65405 09/08/2006 3:38 AM | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | Thanks worked great, the new mount is in.
Kelly | | |
#65406 10/10/2006 2:43 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Under where on the engine are you putting a jack to get the front up enough to replace the F-motor mount? You certainly wouldn't want to jack it up on the pan, would you? Also I'm going to be replacing the rear mounts on my 50, 3600 and need to get it up with out it falling over in the engine compartment, any ideas for that? Denny Graham Sandwich, IL
Denny G Sandwich, IL
#65407 10/10/2006 3:22 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't know if this will apply on your '50 but the rear mounts on my 38 are mounted to a frame crossmember that is bolted to the side rails instead of welded. I simply unbolted the crossmember to remove/replace the mounts.
