| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 18 New Guy | | New Guy Joined: May 2010 Posts: 18 | I'm trying to figure out why the light for my instrument cluster doesn't work. I replaced the bulb, it wasn't connected to the back of the instrument cluster it is just dangling loose under the dash. I assume this light should come on when I turn on the headlights. It's difficult to trace exactly where the wire goes to. It is taped together with a wire that goes to an improvised horn button mounted on the side of the steering column. There's at least a full roll of electrical tape up in there. It then seems like it may go over to the headlight switch, but somewhere along the way I think the wire was added on to with a different color wire because I don't see the gray wire from the bulb end coming out of all the wires that are taped together. Everything else headlights, tail lights, dome light, signals and horn work fine. Can anyone give me a suggestion as to how to troubleshoot this problem. Or tell me how the instrument light should be connected if I just need to re-wire it. In case you can't tell I am electrically challenged. Any help would be very appreciated. Thanks - Al
1958 Chevy Apache 3200
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | the light grounds to the housing and then it should light. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Papa is right, it has to be grounded. Accually there are 3 inst. lights in that dash. They use a light grey wire. There are bulbs for the turn indicators, one light blue & one dark blue. There is a high beam ind. light also but i don't recall the color. The grey wire goes to a reostat on the light switch that you turn to brighten or dim it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I had the same exact problem with the Blue Funk, Al. Everything EXCEPT the instrument lights worked.
Having more money than sense, I went ahead and replaced the headlight switch. The old one was pretty tired-looking anyway.
You can order a replacement switch for about $25 from Classic.
Or- you might just try removing the headlight switch and cleaning up the connections. If nothing else, it'll give you some experience fiddling around with the electrical system.
In the past, I've avoided fixing things because I've broken things more than they were already broke.
So from one novice to another, it's a little difficult to break a headlight switch. Especially one that's already broken. Or not.
Good luck to you, Al.
