| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | where do i start to id my truck corretly? I have a '59 Apache 36 w/ a 261 4-speed and mainly want to see if this was correct from factory. It has offset rearend, previous owner had no additional info. Vin reads 3E59J110329
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 3E = 3600, 3/4T, 123.2" WB 59 = 1959 J = Janesville assembly plant 110329 = factory vehicle sequence # [serial]
beyond that, whatcha see is whatcha got - as far as the specific equiupment [engine, etc] the only way to tell is to find the numbers on the pieces and see if the date codes are 'about right' ... the rear is likely the standard 4.57
Bill | | |
