3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#652182 06/04/2010 3:05 AM
Y
Y Offline
I just aquired a 61 235, thats going into my 51 Burb. I've install an HEI dizzy out of a 69 250, and I'm wondering what spark plug works best with HEI. Should I stay with the recommended plug for the 235? Or maybe go with the 250 plug? Thanks in advance.
With a 235 head, I would go with a 235 plug.
1951 restoration on website
http://www.hanklong.com
Spark plugs for HEI ignition usually have an internal resistor. I understand that the resistor is there to increase the reliability of the electronics.
Stuart.
the resistor is there to suppress radio interference, which can damage the ignition module and be annoying if you have a radio in the truck
50 chevy 3100
When I installed Langdon's HEI in my 235 I asked Tom about that, he said just use the normal plugs but open the gap up to .050" to .055"
I have about 500 miles on a set of NGK BR6S plugs. Once I got the gap opened up I have had no problems so far. FYI McMaster-Carr sells a split clamp that works great for clamping the dist down part number 6436k73
Hope this helps.
Jason
