2 members (Frank50, Joe H),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 22 New Guy | | New Guy Joined: Mar 2010 Posts: 22 | Hi All,
I hope you can help me decide if I'm chasing my tail with something. I just finished rewiring my '64 C20 with reproduction harnesses being careful to hook things back up how I found them. After starting the truck last night for the first time and idling a few minutes I thought I would feel all the wiring under the hood to see if anything seemed too hot...well I found the engine harness to the solenoid/starter was very hot! Is this normal...I've heard of "heat soak" with GM starters...is this what they are referring to?
Or, do I have something hooked up wrong at the solenoid? The shop manual shows a wire(+ from battery) to main post "B", then pink and yellow to the "R" post, and finally purple to the "S" post. I have a extra black wire (ground?) coming from the harness but the shop manual does not refer to where this should connect? This same black wire was on my original harness and was attached to the Main + post on the solenoid.
Thanks in advance!
1964 Chevy C20
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It probably has a resistance wire in the harness for the coil. If there is no ceramic resister on the fire wall hooked to the coil then this is the case. It will get warm. The wire from the bat to the large post on the sel. should be a heavy gauge wire. 10 or 12 gauge. Ground wires are usually black. If it was hooked to the pos. of the bat. it may have been added in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 22 New Guy | | New Guy Joined: Mar 2010 Posts: 22 | Thanks, you got it exactly right! Before I read your reply I had called M&H auto wire who manufactures this harness and they also said that the braided wire is a resistance wire that takes the battery volts from 12 something down to 9.5 volts for the distributor...so it will get warm to very warm.
They also verified the extra black wire is for trucks with guages...this particular wire is for the amp meter and it should also be connected to the main post along with the positive wire coming from the battery.
1964 Chevy C20
