1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I would like to put beauty (trim) rings on my 15" 1958 apache wheels. I have the original rims on the truck. I have noticed the reproductions on vendors websites, but they look very "slim" possibly 1" or 1.5". Does anybody know if a 3" beauty trim will work on the 15" inch stock rim? Or am I limited to the smaller sizes? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | picture of an original TF ring - they hafta fit between the bead shoulder and the valve stem is all, depends if that's your 3"s Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 3" will be too deep for the original wheel. I'm running 3" on Blazer Rallyes, and just test fitted one to an original wheel. The original wheel isn't seep enough on the front side to take them. the clips didn't even make contact.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Just the information I was looking for. Thank you--- | | |
