4 members (Otto Skorzeny, Hotrod Lincoln, msmall, Peggy M), 59 guests, and 3 robots.
Topics128,057
Posts1,055,815
#650888 05/30/2010 1:24 PM
1941 gmc zenith 28av11 carb. cold start its fine, stoped a few min. fine. but once the engine is warm and its parked 15 min. its flooded. I have to crank it 30 seconds pedal on the floor and and its smokes up and you can smell the fuel. it did it before I rebuilt the carb. and its worse now after a carb kit.carb was a bit dirty and was leaking from the gaskets. no more leaks. the float looked fine. and was free. carb off you can see fuel in the intake. please help
I like fixing stuff.
katrina #650890 05/30/2010 1:36 PM
Ex Hall Monitor
Ex Hall Monitor
Assuming as you said, the float is OK, it's most likely percolation from manifold heat. Since the intake & exhaust manifolds are intimately connected it's easy for the heat of the exhaust manifold to bleed up to the carb and "boil" some of the gas out of the bowl, into the throat. It's then like trying to start a hot engine with the choke on. My 38 has a similar problem. A spacer between the carb & intake can help. I've read of some having success putting a heat shield under the carb but I've not done that. I just live with it. I make sure when the engine is hot that I'm going to be at my destination long enough for the engine to cool back down before starting again.
Tiny #651266 06/01/2010 12:31 AM
all's fine. some nascar type fuel line insulation. from the fuel pump to the carb. a tin heat shield just under the carb. and not touching the pedal . she starts like a charm even hot....
katrina #651287 06/01/2010 1:34 AM
Crappy gas we got now will cause this.
