Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (baldeagle, 2 invisible), 79 guests, and 1 robot.
Topics128,285
Posts1,058,535
Members48,490
Can a 53 235 babitt be converted to full presure lube by changing the crank and oil pump? has any one tried this?
"It ain't a truck if you can't hose out the cab."
The thrust bearing is narrower on a full pressure crank than the splash crank so some work on the block would be necessary.
My Blog
Thanks for the info, Dave
